sonoransaw
- 2:09 PM
- Jan 7, 2020
- Arizona
AVB, you are probably right....the new carb was cheap, so I just got that...hoping that will fix it...
Yeah next step would have been to put a new kit. Amazed no fines made it in there.
Could the cracked manifold tube be the sucking air problem? They're a little pricey, so I don't want to buy one unless I have to. It's just a slip on fit to the manifold. Hose clamp? Silicone in the cracks???
What has a crack
Cracked upper rubber connecting tube?
IPL https://www.ereplacementparts.com/p...-gas-chainsaw-parts-c-16962_17147_162366.html
Best to identify the leak first. Carb spray all the areas, one at a time until you make it stall. Then tear into that area whether its intake, base gasket, or seals. A pressure/vac test will confirm. I'll sometimes seal up the intake and exhaust, put 7 psi into it and dunk it into my wash sink full of water to see where the bubbles are coming from.
That how I learn the repairs. I got a whole full size pickup load of 2 cycles and went to learning the repairs.Thanks for the suggestions....that may all come into play. I don't know if I'll be able to do the carb cleaner test because I can't keep it running long enough...
As far as the rubber tube...It might be number 18 in that diagram (which is cheap). I thought it was called the “intake boot” part #530035581, which is $25 on Amazon. I'll get a pic of it later to post so I can get the identification right from you guys....
And I totally get the expense and trouble to fix a cheap saw not being worth it (especially when it's your business)....To me it is worthwhile simply for learning. I've never done this before, so I'm totally into learning....
Can be crankshaft seals especially if you are operating in different position when it starts to act up.The ones I was working on would idle all day, but erratic up and down. Hope to get to them tonight. Snow's coming Saturday so I know my customers are going to start dropping off their equipment any minute now! Keep us posted.
