I Know Something
- 7:48 PM
- Dec 23, 2018
- Fairmont, Minnesota
Here's what happened.
Got me a bar and chain today. Eventually got it on. Bar wouldn't fit. Had to slightly file the OEM Stihl bar. Odd. Took it to the garage to cookie up some 12 inch dead oak logs. Started up just fine. Idled about 30 seconds and hit the first log. Died half way threw.
Tore it down a bit and plug came out. Plug was clean as well as the inside the plug hole. Put it back together. It started back up.
Now, it would bog down and died. Sounded like starving for fuel. Took the fuel cap off. Everything looked fine. Pulled the cord. Started back up. Odd.....
Fuel tank vent was starting to make sence. Ran for a bit and bogged. Open fuel cap, put it back on and it ran fine for a small bit. Did this rotation for 5 minutes or so. Then. It took off and ran fine. I'm half way threw its first tank. This can't be part if the break in period.
Any of you run into something like this?
