- 4:54 PM
- Jun 4, 2020
- Scotland
Ok guys. Thoughts on this one please. I’ve just had a 562xp come back in after seizing. First thoughts were something jammed as it was stuck solid. Pulled the jug to find that the big end bearing was seized, it’s had some serious heat through it. Signs of detonation on the piston. Light scoring on the exhaust side but nothing major and the jugs ok. This happened after the fuel was swapped from two stroke mix to aspen. A tank of aspen through it then it seized.
The saw is a 2021 which hadn’t seen much work before I ported it. I’ve ported a few of these now all with the same numbers, same machining etc. This one is the first with issues. Has the aspen killed it?
