Any Chinese chainsaw and chinese parts discussion
Leafy
10:41 PM
NH
I finally got a new coil, got it running, cut some wood with it In the excitement I forgot I drained most of the gas out of it so I only made a few cuts but it went like stink. I filed it back up and it stared but it surged up revs with no throttle so I shut it down. I couldn't get it to restart so I took it back to the garage. Pulled it part way apart, ring is still in it can't see any scoring, plug looks OK, no viable leaks in the intake. I did try resetting the carb adjustments and they were both like 1/4 out... That doesn't seem right. Also looked to have a bunch of spit back in the intake elbow. I'm going to try the other carb I have, maybe it will work better. Otherwise I've got to check harder for air leaks. I hope it's not the oring under the oiler.
10:41 PM
Pull on the fuel hose
Make sure you didn't kink it above the tank.
Put motoseal etc.
Inside the clutch bushing on the shaft.
To make a seal
None of my china clones had an oring.
10:41 PM
@huskihl
You have anything
He's having a time
Leafy
10:41 PM
NH
Other carb isn't really any better, it'll pop every once and a while just enough to make me half to reset the compression release.
10:41 PM
Checked the china fuel line on my last new 20180623_124057.jpg 372
6 out of six failures.
Leafy
10:41 PM
NH
I'll check, my line didn't have the wire on it so I kind of hoped it wouldnt break like that.
Leafy
10:41 PM
NH
Well I know why it stared surging, the jug bolts were loose. Must have not had them tight enough and they vibrated loose. It still just pops when pulling it though.
10:41 PM
Do you have a way to pressure and vac test?
Leafy
10:41 PM
NH
Yes. It holds 15 inches of vac no problem.
10:41 PM
Finished the second saw yesterday
Raining can't cut today.
The clone saw's use a clutch looking bearing.
So i bought oem husky 372 clutch bearings
And used them.20180623_154315.jpg 20180623_154403.jpg 20180623_144658.jpg 20180623_124354.jpg 20180623_113010.jpg echo 3x6mm fuel line
And done.
Leafy
10:41 PM
NH
It runs again. Different day solved it I guess. But I need more sprocket clips this one is all bent up and won't stay on. I'll measure it later and just buy a 100 pack from mcmaster for $8.
10:41 PM
A
Any napa has them
Got any pics of it
Leafy
10:41 PM
NH
Well it cut down 2 5" oaks, didnt even realize it was touching wood with the fresh upstart chain and 8 pin. It was weird that the chain was throwing sparks in clean wood. The damn think does oil like the exxon valdez, even with the oiler closed all the way it made a whole mess of my garage floor when I was tuning it. I also noticed it needs to have the pto side slightly elevated or else it'll piss itself though the bar oil vent.
smokey7
10:41 PM
Detroit
How do the ported cylinders compair to the 268 popup setup you had before?
10:41 PM
The ported one's will definitely pull a 24 or longer bar a lot better.
With 20s they are similar
You can lean harder on the ported one's.
And they keep rpm in the cut.
Not a racer but they cut faster
It's fun to try different setups
Carb muffler bar etc.
10:41 PM
My truck saw needed sharpening.
Haven't run it much just clearing
Storm damage.
272/372 big bore
Leafy
10:41 PM
NH
Can all your saws just muscle through the chain brake? Mine will still turn like 6-8k rpm on the chain brake. Even just from a stop, I haven't tried engaging it while wfo.
