- 3:29 PM
- Dec 26, 2015
- The land of pleasant living
So I changed out my 288 lo top for a high top set up. Everything is tight and it used to start up fine. Now when I start it up it spits on choke, when I push in the choke to start it again it will idle fine but when I go to throttle her up she bogs down to the point where I've got to feather the throttle to get it running, but once she's running it fine. Can let her settle down and when I throttle her up she has good response. Did the hi top air filter change the flow of air to the carb? Maybe try a different starting method? Or mess with the low side screw to lean it out a little? Was going to see what you guys think before I get into it. All I've done is adjust idle and hi side so she has got 12,500 unloaded. Still 4 stroking. Any thoughts?
