TheDarkLordChinChin
My name Borat, I like you
- 3:01 PM
- Feb 2, 2020
- Ireland
I bought a 281xp about 2 years ago. I used it for a bit cutting big leylandii trees (very bushy softwoods that are good for nothing) and liked it.
I went to use it again in southern beech a couple of months later and the chain would not budge.
I left it lying up for 18 months or so and came back to have a look.
When I tighten the bar nuts down the chain pinches in the top bar rail very close to where the chain exits the saw.
If I leave the bar nuts a little loose I don't get the same problem but they can rattle off.
Chain tension makes no difference, you can visibly see the one drive link getting pinched in the bar rail.
Could it be due to the aftermarket clutch cover? The bar nuts always feel like I can tighten them down more, maybe the metal in the clutch cover is softer than OEM and is being tightened down too much?
Or maybe there is something missing either in the saw itself or in the clutch cover that prevents the chain from being pinched if you over-tighten the cover.
If anyone had any pictures of the inside of a 281xp clutch cover as well as pictures of the exposed clutch mechanism and sprocket/chain tensioner it would be much appreciated.
Thanks.
Thanks.
