- 9:26 AM
- Aug 27, 2023
- Pennsylvania
Hi guys. I’m new here. This isn’t about a Homelite, but I found an Oregon 24” bar for my 820 Jred that I was told would fit.
But it has a 9.5mm slot and the 820 bolts are 10mm. I’ve heard there may be 9.5 Husky bolts that will fit in an 820/920 chassis. Any advice for me?
I can return the bar…or open the slot up that .5 difference.
Thanks!
Thx for the input. I was about to do that when my local saw shop called back and said they’d found some OEM bars at 10mm. I reluctantly returned that nice Oregon bar.Check and make sure the bar oiler hole lines up with the oil hole on you bar pad. You can check by laying the inner bar plate over the bar to see if it does line up. If it does, go ahead and open the bar slot so it fits. Take some off both sides of the slot.
