72thing
Chain dulling master
Need an OEM 046 cylinder to make my MS440 into a hybrid. I don't know enough to have a preference on which type (D or hemi), as long as it is cleaned up or can be cleaned up.
Thanks!
Thanks!
trooney, I responded to your PM.
And Cracker Boy, thanks for the info. Any idea about the piston? Should I seek OEM or would I be OK with a Meteor?
What do you mean in depth thread.and extra works sometimes.can you please explain.thanxWill,
There is a very in-depth thread going on here on OPE: please check it out.
There seems to sometimes be some extra works.
I’ll pay you for your 50mm Top End if you Agree to sell.
OEM Piston Prices Have come Down lately.
Hit UP Diamond Dallas Dave’s CCC page on the bay & see what he has.
Shoot when i was looking for a p/c for same thing i got goose egg replies.it sat up there for quite a while i found 3 elsewere.im trying to share what i learned to do same saw talking to the porters.mine is a runnung complete 044
Iirc the cylinder mount holes need to be elongated also.I saw the part about the cylinder to case clearance...looks like some light grinding is all thats required.
A few fins need to disappear as well.Right you are. But no machine work involved just fitting the cylinder to the host 044. From all I understand--Grind base to clear crankcase, slot the base holes, and grind the exterior transfer area to clear the flywheel. Then let someone work their magic inside
It only gets worse my feiend,Gotcha, thanks for the info, doc. It's so nice getting great advice from members on here. I'm relatively new to this forum but not to chainsaws. After attending Randy's GTG I have the bug worse than ever before!
