HELP! 036 air filter upgrades
Jscb1b
Mister Slapnut
5:00 PM
AZ, USA
I have an 036 that a lot of fines get inside of the carb throat. I'm using the flock style filter. I've read about greasing the base. Are there other tricks to try?
8:00 PM
Use an OEM filter that flows well. The AM seem to not be any good. There will be less vacuum to deal with in the filter.
Make sure there is a good seal between the carb and filter. Make sure both face are flat. Certainly make sure you aren’t using the new style replacement carb with the old style filter. The filter won’t sit flat on the carb at all, the comp horn will hold it off the carb.
There is a gasket included for the carb in the OEM kits. The old models used it between the carb and boot back in the day. See if it fits between the carb and the AF. I haven’t tried to use it, but it should fit.
Clean filter and tape the seams shut.
Sharpen your chain so there aren’t as many fines to start with.
Add a Frogzskin adhesive backed screen to a hole you drill on the Flywheel side of the air filter cover. It will reroute the air flow and decrease the amount of dust the entire airbox air breathes in by redirecting flow. I know it makes little sense, but it actually works.
That’s all I got.
5155
8:00 PM
pa
There are at least three different flocked filter part numbers for my 034. I've not figured the why other than differing tank vents. Shops I have tried make this very difficult for me.
I should try Drs frogzskin comment.
Jscb1b
Mister Slapnut
5:00 PM
AZ, USA
Frogskinz are ordered. I dirko'ed the filter to the carb. When I removed the filter, the dirko filled in the low spots.
Jscb1b
Mister Slapnut
5:00 PM
AZ, USA
Pictures of filter and carb. If you look really close, you can see the gap between the filter and carb. Looking at pictures online, show a gasket or o ring in the filter base. 20231001_120306.jpg20231001_115741.jpg
