Ketchup
Epoxy member
- 8:09 AM
- Mar 12, 2018
- Colorado
Hi Guys
I’m porting an 026 for fun and thought I would try some finger ports. My plan is a tight squish (0.018”), wide exhaust (maxed out but not raised much), “Mushroom” Muffler, light intake widening (shooting for 74-75 degrees opening) and lower transfer cleanup. Sounds like people do fingers but I couldn’t find specific info.
So:
Should I end the fingers above or below the mains? Stock Blowdown is 24 degrees. I feel like I could raise the uppers a bit and shorten the blowdown.
Is my exhaust plan excessive? Will it affect transfer velocity?
Is there a piston I could swap in with a centered single ring? Especially with a slightly longer skirt?
Does a bigger carb help with the added transfer?
The saw is fugly, so no concerns about hacking it up.
Any thoughts or info is appreciated!
So:
