bikemike
- 7:36 PM
- Feb 4, 2016
- Cottage grove mn
I've got a 365xt p/c that looks like that. Don't really know what caused it ,as it was a parts saw when I got it for the cases. But the big end rod bearing was completely gone.200t air filter cover caused all this.
Should buff out
Is it different from other years? Every year I've had it, it's been the same.I really like this year's Sam's Octoberfest … good stuff … I'll have to get more of it.
Should buff out
Sounds familiar...
A friend of mine knows I like to work on chainsaws, so he brought me this basket case from his brother-in-law.
They couldn’t figure out why it blew up...lol.
Little Halloween spirit on the bench...
550 needed a little breaking in, so I carved a jack-o-lantern.
The 550 rips and the wife loves the pumpkin...
You can "suddenly" cut more wood than you care to haul!Just finished a 357/359 build. It’s a low hour 359 with a scored piston. Had a plastic intake clamp that was easily pulled off with my fingers. I picked up a 357 cylinder with the auto decomp and plugged the smaller fitting. I installed a meteor piston and caber ring. The carb is a Walbro 199 that runs great, but I need to remove the plastic limiters. No stuffers.
I advanced the timing and removed the base gasket. I cut with it today and am pleased how it ran. However, I have a ported 357xp so I was not blown Away. View attachment 142134View attachment 142135View attachment 142136View attachment 142137View attachment 142138
Is 3/8 or .325better for pumpkins?
