SlovenianUsername
OPE Member
- 10:24 AM
- Dec 30, 2023
- Slovenia
First some history. I bought a used spider lift that was fitted with honda igx440. The thing ran good only in summer, but even then, one had to always use starter spray to for cold starting.
The igx series has no manual throttle, instead it has an ECU which drives the so called self tuning regulator, STR for short. When ECU senses that the engine is loaded, it picks up the engine rpms. When not under load, the rpms go down, engine goes to idle speed.
Problem with my engine is, it is surging really badly while idling. When I for example want to extend the boom, the STR picks usually up the rpms, and it has a nice sound. But also what happens very often is, the rpm doesn't go up, and the engine just shuts off in a few strokes. Like a half dead horse when put through burden.
The problems usually start when it gets a bit colder, 40 degrees fahrenheit, or 5 celsius, I am certain to have problems.
Today I made a bit of a progress, I decided to open the ecu. That's the thing with the red LED on, the low oil shut off.
The protective rubber is at some spots melted away. Altough the pcb looks ok, no visible damage.
Then you remove the PCB, you just lift it off, and underneath you get another clue. Two small stepper motors.https://www.nipponpulse.com/products/Motors/motors-rotary-tin-can-steppers/PF35T-48R4
its operating temperature is -10 to +100 degrees celsius. They must have melted the rubber, but ok, let's move on.
I unscrewed the 4 philips screws, and the next thing unveils. Finally I come to the part that now opens the carburetor butterfly valves. One for each butterfly valve.
So two gears, for two butterflies, and underneath them, something black with a spring- and this is the only thing you can actually grab and turn, the thing has a lever on the outside of carburetor. When the engine is working, the lever doesn't make any difference, whichever way you turn it. No change at all.
Anyone know what that is?
But I don't think that's the culprit, as the engine was working really good in summer. I don't know much about carburetors, but just thiking out loud: could one just hard wire the thing to stay always in full throttle mode? So let's say could I force the butterfly valve to stay always open?
Oh, and the last thing. What if the damn thing, this ECU is working good. Could it be that the load sensing part is not working? How does a machine even send a signal that the hydraulics is under load?
Feel free to discuss, any input is appreciated.
Edit: just a link to a picture with feature of ECU http://visman-co.com/other/ENGLISH/Engine/gx_series_commercial_grade_igx45.htm
