- 11:37 AM
- Apr 13, 2020
- 5543X, 5644X
I used Randy's @Mastermind ideas Non acid transfer removal I had fairly good results.
It's as dry as a desert under the piston the side air filter is clogged and I'm worried about the black clutch drum. The H&L screws in the carburetor are slightly unscrewed
I think the cylinder is poorly screwed in and the screws in the carburetor only need one turn, the screw was screwed in the fuel tank vent pipe / The instructions refer to the initial setting of 5/4 screws in the carburetor / The screw in the cable is also in the parts catalog and I thought I invented it
Mine looked very similar when I tore it apart. I had a seal that had not remained seated properly on the clutch side. It had cocked 10-15 degrees, and was one with a rubber mating surface to the case. Both seals got replaced with seals that were metal(case side) and double lipped. Also check the fuel tank vent line, mine was missing the external vent and had been plugged. Maybe contributed to part of the lean condition.
Did you also have such a dirty crankcase Inside ? see previous photo
It's about this dark coating under the pistonThere was a small amount of cleaning to do, crankcase wise. I didn't remember to give it the air hose cleaning before I started taking this saw apart. Won't forget to do that for a while.
It's greasy and can be wiped off with a cloth, a residue from bad oil? Or maybe someone poured different oil into the fuelPretty sure it was dark - carboned, but not sure if I'm remembering the right saw piston. I'll get a picture, but it will take a couple of days to get to it . . .
Definitely yes!They worth the time porting?
I had 681 at this price and I regret not buying it / head only without cutting setGood Day all,
Bought this Solo 675 because it looked a deal at $150 USD,
It's almost new condition apart from a broken clutch spring and missing filter clamp wire.
Cheers
