661 Limit Tabs
silverpsd06
OPE Member
9:09 PM
Ottawa, KS
Does anyone know how to remove the limiting tabs on these? Doesn't seem to have enough meat to get a drywall screw to pull the plastic piece away from the metal like on older saws. Is there a tool to use? Never had the red ones whip me like this.
AnthemBassMan
10:09 PM
Ohio
They do make a limiter cap removal tool. It just looks like a screwdriver with a fine threaded tip. Or you could try the cheaper route and try using a machine screw. The flat end may get you enough bite unlike the pointed end of a drywall screw.
L8R,
Matt
bogieboy
10:09 PM
Rochester, NY
second the machine screw idea.... also, there is a tab that should line up with that small slot to make it easier to pull off....
