StarWolfQTP
New OPE Member
- 9:36 AM
- Apr 18, 2024
- Clinton,MS
Hello, I'm the owner of a Poulan Pro HDF900 front tine tiller powered by an LCT 208 engine model PLMHK14650124PBPQRSUVE2M. After many maintenance parts, belts spark plug etc, I attempted to pull start the tiller and it started on one pull to my surprise, running like a champ.
For about 20 seconds until I experienced a back fire with an explosion. The on/off switch has blown out and there are magnetic pieces of metal and some plastic under the flywheel. Upon further inspection, the outer flywheel magnet has disintegrated leaving only the screw.
Is there a part number for this particular part or a list of dimensions for the magnet itself? Any help would be greatly appreciated. Thank you.
