- 9:01 PM
- Jun 5, 2016
- Northwoods of Wisconsin
Selling a XS ported 562XP PHO for $550.00 firm plus actual shipping quote.
What it is,
An older used saw left with me after it was decided not to repair by its professional use owner.
EPA tag lists the year date as 2012. It's an oldie but still a goodie, especially for firewood duty.
Saw has scratches, paint missing and faded plastics and pitchy.
Repaired mechanically by me for someone to have a nice cutting firewood saw.
What it isn't,
A polished show unit, that day has long passed.
What I did,
Cleaned up the cylinder every which a way including a light trim on the base, replaced the piston, the oil and fuel delivery systems, as the saw had a leaky base, leaking oil pump and off idle bog.
What I didn't do.
Mess with the build design as it was done originally.
New parts I used,
Aftermarket,
Meteor Piston and Caber rings
Ultra thin base gasket
Stens True Blue starter chord
OEM
Oil Pump
Oil line
worm gear
rim sprocket
fuel filter - Blue
Gasket and Diaphragm kit
Fuel inlet strainer screen
NGK spark plug
Engine and carburetor have been pressure/vac tested and test ran, saw starts up and runs well, revs up good like it should and is oiling great.
This should make someone a good firewood cutter that wants a saw to use and not to polish at a great price.
What it is,
What it isn't,
What I did,
What I didn't do.
New parts I used,
Aftermarket,
OEM
Oil Pump
Oil line
worm gear
rim sprocket
fuel filter - Blue
NGK spark plug
