KUDOS Withdrawn
Trader history (2)
HumBurner
3:47 PM
Humboldt
Up for sale is a set of projects I acquired. My living situation has taken a turn for the worse (slumlords, yeeeesh!) so I'm moving. I won't have space at the new place, so stuff has to go.
20230303_072045.jpg20230303_072036.jpg20230303_072006.jpg20230303_071954.jpg20230303_071630.jpg
The AV unit runs but needs going over, carb cleaning and possibly a kit, fuel lines checked. I put three tanks through it last month, but the carb is very touchy and won't hold an idle well. Currently has 3/8 rim-sprocket.
The AVS unit was sold to me as a non-runner. I got it to start, but the gas tank leaks (maybe just from the cap, but pretty sure it's the handle) so it never received extensive testing. Sold as is.
I had a trade going with a fairly well-known member here for all the additional parts and spare crankcase. It took over 9 months for the seller to send me the parts. I lost my window for tinkering while waiting and don't know when it'll reappear.
Used crankcase but in good shape. Flywheel, spare carb (diaphragms/gaskets may need attention), complete top end (not sure which spec), seals and case gaskets, spare top cover, tank-handle, new/unopened 3/8" conversion kit, drum, etc. See photos and feel free to ask questions. I have the other flocked filter somewhere in a bag with other filters needing to be gas-bathed.
HumBurner
3:47 PM
Humboldt
I also have two 3/8" 16" bars and 3 or 4 semi-chisel full-comp chains for these saws. Can check gauges later on. Can add them in the package for a little extra, otherwise I'll post a separate ad.20230303_070417.jpg20230303_070351.jpg20230303_070405.jpg
HumBurner
3:47 PM
Humboldt
These units and parts have still been sitting in their tote.
$600 shipped to the lower 48. Cash preferred but open to trading for a good and clean 242xpg/346xpg/543xpg/357xpg.
HumBurner
3:47 PM
Humboldt
024av unit. Not as pristine, but still good with machine marks. Light scoring/exhaust marks in the cylinder wall. Both saws have strong compression by feel.
HumBurner
3:47 PM
Humboldt
Bar and two brand new chains. There's a third chain floating around that had a couple of tanks run on it that I'll try to find.
$75 extra shipped.
