Wire Mesh Face Shields
Merkava_4
7:21 AM
Clovis, California
They're supposed to be real good at protecting you while using a chainsaw, but I'd be using while using my string trimmer.
The wire mesh seems like it would resist fogging up in the cold weather brilliantly.
I currently use a NoCry clear plastic face shield and let me tell you, it has saved my face and eyes many times over.
Here's the question : For you guys that have used the wire mesh visors, how well can you see out of them clarity wise?
ammoaddict
10:21 AM
Granite Falls, NC
I use my chainsaw helmet with mesh shield while trimming. You can see well with it except when the sun is in your face.
Merkava_4
7:21 AM
Clovis, California
Do you guys wear safety glasses under the wire mesh; or don't you think the wire mesh protects you good enough by itself?
hacskaroly
2100 Fanclub Member
7:21 AM
Northern Idaho, Ehh
Yeah, I forgot to mention, I do wear protective glasses under my face shield, I have had a number of times things ricochet off my chest and bounce up off the back side of the face shield and onto my face....glasses saved the day.
Woodtroll
10:21 AM
Mtns of SW VA
When I weedeat I wear an old Stihl ear muff/mesh shield set, and just bought a similar setup from Bailey's for my grandson. I can see through it very well, unless the sun hits at just the right angle, then there's a "glare" on the mesh.
I wear large-lense prescription glasses with polycarbonate lenses all the time; if I did not I would wear safety glasses with the shield, at least while weedeating. I don't use the mesh shield while mowing or cutting wood, but I'd not be without glasses of some type while doing either.
ammoaddict
10:21 AM
Granite Falls, NC
When i mow i wear earplugs, dust mask and safety glasses so if I need to trim a little after mowing that's what I wear.
Hinerman
9:21 AM
NE OK
The wire mesh works great; visibility is fine. My problem is the durability. I sweat profusely. The wire mesh can rust away after a few uses, so it is not an option for me; at least not an affordable option.
Hinerman
9:21 AM
NE OK
I sweat a lot too but I haven't noticed any rusting. Mine might be plastic, I'll have to look.
If you have a plastic one, let me know because I want one. I like the face shield; they work. I did not take a picture but I had a big splinter fly under my safety glasses (while running trimmer/weed eater) and stick me right below the eye (was not wearing face shield). I was shocked that it got behind the glasses and that close to my eye.
Woodtroll
10:21 AM
Mtns of SW VA
I’ve had that same problem, although not to that extent. I hit mine occasionally with flat black (to reduce glare) Rustoleum occasionally, brushing with a soft bristle stainless wire brush to remove buildup from the last coat. It wouldn’t take much to start filling up the screen, so I use quick light passes.
ammoaddict
10:21 AM
Granite Falls, NC
Mine is the homeowner Husqvarna helmet not the more expensive pro helmet.
Merkava_4
7:21 AM
Clovis, California
I was thinking maybe some of them might be a plastic mesh like they have in some oil filters.
