Willard
- 11:38 AM
- Apr 13, 2017
- Manitoba
I measured the sleeve thickness in the CR250 and if I bored it out completely I would end up with a 72mm aluminum bore.
From what I can see with the sleeve removed the ports would basically retain their same dimensions.
So can I get the aluminum cylinder bore plated with say nikisel?
Then I would have 300cc with a square 72mm×72mm engine?
