Why is a wide nose bar better?
heimannm
7:22 AM
Dike, Iowa
The chain make a slightly less dramatic change of direction when going around a wide nose bar so it does go a bit more smoothly. With hardnose bars is also reduces the pull on the nose (spreads it out over a wider area) so the bar tip will last longer. I have only seen a very few hardnose bars that ever worn out the stellite on the nose.
Mark
jmssaws
Banneded
7:22 AM
I have many wide nose stihl bars and the only thing I don't like about them is if your chain is aggressive at all it makes punch cutting with the nose almost impossible. Like I said earlier it's supposedly for boring but it's not good for it. The narrow nose is much easier to bore with.
A mean chain and a wide nose is hazardous to a man's health.
Philbert
Chainsaw Enthusiast
7:22 AM
East Dakota
The main reason is reduced friction.
Pulling a chain (rope, cable, etc.) around a larger radius curve reduces friction/resistance, and therefore, heat, wear on the bar, strain on the motor, etc. With a sprocket nose, a larger radius means that they can pack a few more bearings in there as well.
The larger radius also provides a larger area (lower quadrant) that you can bore cut with. The downside, is that it also provides a larger area (upper quadrant) subject to kickback. Some manufacturers tried to address this by making 'banana bars' that had an asymmetrical tip (smaller radius on the top, larger radius on the bottom).
Larger radius bars s*ck for carving.
Many guys probably want them just because they can't get them anymore, so some sellers may try to jack up the price, based on scarcity.
Philbert
CR888
10:22 PM
Australia
Chain is heavy and modern saws rely on chain speed much greater than saws of years past. Tha rapid change of direction on a small radius may reduce kick back significantly but robbs power in doing so. It means the sprocket has a harder life too but studies over many years show a huge reduction in kick back related injury when using smaller radius noses. You can always replace a bearing or improve a saws power to make up the small amount that is lost. Telling a sawyers wife why her husband is in the emergency dept is a little more difficult to explain I guess.
srcarr52
8:22 AM
Iowa City
A regular 3/8 tip had 11 teeth.
Old school Oregon large 3 rivet tip was 12 teeth, the 3 rivet tip for shorter bars was still 11 theeth.
Stihl wide tip is 13 teeth.
Like any chain a larger radius sprocket is more efficient because their is less parasitic loss. For example, the chain has a centrifugal acceleration from traveling in an arc, the internal forces of the chain pins have to resit this, as the radius get smaller, the forces go up by a power of 2 and the loss due to fiction increase according to the pin force. As well that is not the only force associated with loss in the system that goes up as radius decreases.
darkimpulse
Firewood Hack
9:22 AM
East Coast, Canada
Only thing I have noticed is that narrow nose bars are good for reducing kickback while wide nose bars seem to have a much better boring performance.
Philbert
Chainsaw Enthusiast
7:22 AM
East Dakota
. . . the chain has a centrifugal acceleration from traveling in an arc, the internal forces of the chain pins have to resit this, as the radius get smaller, the forces go up . . .
Interesting. I was thinking only about cutting efficiency - never thought about different wear on the chain!
Philbert
cgraham1
5:22 AM
Nor Cal
So, is the wide nose better? :crazylick:
maulhead
6:22 AM
Home
The reason I ask, is that I saw a wide nose for sale somewhere and the guy wanted twice what a standard ES bar would cost... and now it's sold. Why would someone pay that much more for a wide nose bar over a standard bar?
Do you have a link to this wide nose bar that was twice as much?
I have a wide nose bar, and have noticed that it cuts smoother (less vibes) vs a regular ES bar of the same length. Switching back & forth, from the narrow to the wide nose bar, on the same saw using the same chain, I can tell a difference, the wide cuts smoother. The wide also is faster, not night & day faster, but it's noticeable to me.
Redbull did some test of wide vs narrow bars, If I recall correctly the wide had 8-9% faster cut times.....
