Week clutch spring 038
merc_man
merc_man
6:55 AM
southern ontario
Got a 038 that the chain creeps all the time when on idle. ( not idled too high)
I pulled apart to inspect to see if a spring had broke but not the case. I can wiggle the clutch shoes quite easy. I would guess they should be more secure in ther?
Also should i replace just springs or the whole clutch. Clutch dont slip in the cut just spins chain on idle.
Are the after market clutchs any good. I can get one for little over ten buck on ebay but will take up to end of november for delivery.
Bigmac
3:55 AM
X2 on the oem spring! Have had hit and miss luck with aftermarket clutches, I had a hyway 660 clutch split in half on the hub!
