Walbro hda-196
idiotwithasaw
12:36 AM
Ky
Is this a desireable carb? I have read that the 198/199 is what you want in a 346 build instead of the zama. Would the 196 be similar to the 198 and better than the el-32 zama?
The reason I ask is because I already have this carb and it seems to work fine, I was gonna build a 346 and wanted to know if it would be enough of an improvement to justify making it work?
Tor R
Novice, Leg model #2
8:36 AM
Mandal
I don't think HDA 196 is the same size as HDA 190, 191, 198, 199.
350 had an HDA 195, same size as HDA 182 who was used on 346, exept that 182 has acc pump while HDA 195 hasnt.
The same goes to the 4 I named, 2 had acc pump, the two other not.
idiotwithasaw
12:36 AM
Ky
What was the 196 on originally
Sent from my HTC One using Tapatalk
Tor R
8:36 AM
Mandal
On ebay it's advertised to be for 350.
There was a few years they used HDA 195 on 350, never seen 196 named there
