SOLD Vessel GT-3500GE 1 IN GAS POWERED IMPACT GUN USED ON THE RAILROAD TO TIGHTEN tressels
Pugsley555
8:14 PM
Fairview
IMG_20190712_144421716.jpg IMG_20190712_144239295.jpg IMG_20190712_144235635.jpg IMG_20190712_144441764.jpg IMG_20190712_144435313.jpg Mostly used by the railroad to tighten tressels is a Tanaka powered 1" monster impact gun. Starts fairly easily and runs great. Has forward nuetral and reverse all of which operates as they should.
Fan casing has been changed due to damage that caused the coil to loose its ground. while repairing this i also powdercoated what could be and the parts that i didnt think would withstand or be good to be in the oven at 400 degrees for 20 minutes i applied high temp enamel. The carburator was totally rebuilt down to the welsh plug using a original walbro kit. The fuel lines, filter, and air filter were also replaced. The cylinder, piston, and rings are all in exellent condition and saw no sighns of excessive wear or burning of "unhealthy gas". This machine has been fine tuned and is ready for work. $650 OBO paypal friends and family or if you feelthe need to use paying for goods and services please add the 3%. Feel free to PM me with any questions. i am somewhat open to partial trades.
MORE PICTURES BELOW
7:14 PM
Is this based off an Echo?
Pugsley555
8:14 PM
Fairview
I'm not too sure on that I've tried to look more into it I know that it is Japanese bass company to me yes it does look like one as far as the parts are concerned but if nobody messages me within the next day or so I'm going to take it apart and try to get a coil and a carburetor kit already have so I'll probably end up just fixing it if nobody else calls and just sell it for some more profit. I do have a gas-powered Echo drill and some Tanaka gas powered drills
timg
8:14 PM
Keystone State West
Gonna need a boom truck to tug that bad boy around Pugsley.
Pugsley555
8:14 PM
Fairview
Oh yeah I got a bad back as it is but no worries I've got a HWH hydraulic pad leveling setup. Pump, Reservoir, and motor in one so I'm like 10% on my way to building a boom truck...lol
Pugsley555
8:14 PM
Fairview
It's based off of a Tanaka I actually downloaded the service manual and specs on it. These bad boys go for up to 1200 2 $1,600 for used ones. I believe the only thing wrong with it is the fact that whenever it was dropped or whatever damage was done to it it busted off the coil ground. it has excellent compression and seems to all be in working order other than the fan cover being broken and handlebar bent.
Pugsley555
8:14 PM
Fairview
Fan casing has been changed due to damage that caused the coil to loose its ground. while repairing this i also powdercoated what could be and the parts that i didnt think would withstand or be good to be in the oven at 400 degrees for 20 minutes i applied high temp enamel. The carburator was totally rebuilt down to the welsh plug using a original walbro kit. The fuel lines, filter, and air filter were also replaced. The cylinder, piston, and rings are all in exellent condition and saw no sighns of excessive wear or burning of "unhealthy gas". This machine has been fine tuned and is ready for work. $1050 OBO paypal friends and family or if you feelthe need to use paying for goods and services please add the 3%. Feel free to PM me with any questions. i am somewhat open to partial trades.
IMG_20190712_144421716.jpg IMG_20190712_144239295.jpg IMG_20190712_144235635.jpg IMG_20190712_144432563.jpg IMG_20190712_144424741.jpg
