Thinking of something like this. That has a 32mm od on the velocity stack. Shorter pipe and a steeper angle off the carb block. A thinner block would work better as well.
On a side note for you guys running velocity stacks do you have a problem with the switch shafts on the stihls popping out of there seat?
