Test - Bosch vs NGK plug
Keith Gandy
Maxima K2 40:1 87 Pump Gas
1:42 PM
Provencal, Louisiana
I guess feel is deceiving because I would of sworn the bosch was stronger in the cut when I was doing my 5-6 warm up cuts in another log not shown.
Use a “warm up” chain
Saw idle with new plug for about 30sec
Then go 5 or 6 cuts in big pine log TM didn’t want
Switch to new chain- do cut in cant.
Same process for the ngk.
Could NOT get the bosch to go over 13,320. I was like wtf. Cuz ngk was 13440.
U r one testin son of a gun!!!:D
RI Chevy
2:42 PM
earth
We need to separate the conversations in here and start a separate thread for the ATV stuff. It is getting hard to follow. Leave this thread for the technical testing on just the plugs and the saws.
Cut4fun
Redneck Chainsaw Repair
2:42 PM
Ohio
I need to see if I can find that old plug that came out of my ole alky MVP166 when I took it on trade. I thought WTH.
I put in the shorter cooler running Bosch. I may still have it in a old plug bin I forgot about.
See if I have a pic of that long sucker.
RB where was your Bosch plug made at on side of plug. I have yet to see a china made OPE plug by bosch in ones I buy.
My last batch of 5 6 7 were 5 German and 6 7 Brazil still. I order in bulk from NWS.
1:42 PM
That's sorta the nature of forums.......most threads will meander around a bit......then back to the original subject.
Cut4fun
2:42 PM
Ohio
You can see the shorter bosch 5E I like to run in my race stuff back in the day. 376 had a 038 mag piston. Back before the wiseco 52mm were being sold by EHP.
