Recently I purchased a Husqvarna 545. A compression test showed about 110 psi. My tester is a MityVac and I used the 14mm to 10 mm adapter. I have read that using adapters throws the compression off. I would like to know why. Since the MitVac hose has the schrader valve at the tip, adding less than an inch of an adapter should not significantly change the readings. And yes, using the hose (14mm thread) correlates with another gauge that I have.
I also purchased a 576xp and compression testing without the adapter and using the 14mm hose with schrader valve at the tip, yields similar results.
So ... do strato saws not show expected results when doing a compression test?
