SOLD Stock 460
mdavlee
Hillbilly grinder
10:56 AM
TN
I'm going to be home next weekend and I'll have time to port and assemble another 046/460 if there's interest. This one is pretty nice to start with. The muffler bolt on the case has been jb welded and tapped back to original size. Tank doesn't match with the newer 460 tank. I have all the brake parts to put on there from the other buckets of parts. New oem piston will be installed. Price will be $400 stock or $600 ported.
PA Dan
10:56 AM
White Oak PA
$600 for ported 460! Shouldn't last long!
Normzilla
7:56 AM
Cazadero CA
Nice saw. Very fair prices.
RI Chevy
10:56 AM
earth
Lol. What is a loose pocket?
RI Chevy
10:56 AM
earth
Ahh. Definitely no good
mdavlee
Hillbilly grinder
10:56 AM
TN
I have one ready to go. All oem gaskets, bearings, seals, and piston. I need a brake band for this one. I have a nice handle to put on when I find a band. I have a nicer top cover I can swap. The air filter cover is cracked. I don't have any others unless you want the max flow set up. I can swap a modded muffler on there. I'm a little busy with other saws so porting isn't offered on it for the time being. $500 plus shipping for power head. If you want the max flow add $40.
mdavlee
Hillbilly grinder
10:56 AM
TN
I do have a new aftermarket clutch cover that's made a few cuts. I forgot the ugly one was on there for test cuts. Small stock spike will be installed as well.
