Stihl SH 85C Blower Carb
toolmaker
5:15 PM
Tyrone, Pa
Can someone please tell me what carb I need for a Stihl 85C Blower, and best place to buy one?
I know it's a Zama Q1C, but I don't know the rest of the part number
Thanks!!
Wonkydonkey
Plastic member
10:15 PM
Sussex, UK.
After a quick look around. Your carb could be a c1q-s64 or 68 in which case the carb kit would be RB89 , but try and double check,
Unfortunately the zamma page don’t seen to list the carb kit
If you follow my link on the zamma page. You can change the carb type at the end to bring up the pdf diagram. (In capitals) but it just comes up with the generic c1q
Edit zamma page
http://www.zamacorp.com/tclist.html?cnum=C1Q-S68H
CB4193AD-0081-4AB2-AE5E-8B70019421E2.png 97CF3342-CFDA-4E3D-BBE9-795F0AF906F9.png
Wonkydonkey
Plastic member
10:15 PM
Sussex, UK.
I,ll add this here, I just looked up sh85c on diyspareparts and not the bg85 :rolleyes:
i see there are other carbs listed ;)
https://www.diyspareparts.com/parts/stihl/diagrams/sh-85/0b98eebc-4795-4a25-b55e/
maybe you could work it out like I tried before ;)
Al though I still think the same carb kit as I said above will fit as the other link says it’s compatible.
Edit.
You could also look at this site for info & reference
https://www.lsengineers.co.uk/set-of-carburetor-parts-stihl-part-no-4229-007-1060.html
AVB
4:15 PM
Pluto
OPPPS. I pulled the 86C IPL. Good catch. Sorry about the mis-info and I have deleted it.
For the Zama RB-89 try Oregon 49-288 or Stens 615-706.
The C1Q-S68H should be same as the older versions which shows the RB-99 kit. For this try Stens 615-221.
AVB
4:15 PM
Pluto
The main difference between the RB-89 and RB-99 is the metering diaphragm and gasket.
RB-89
RB-99
