WANTED Stihl S-10 rear handle parts
Definitive Dave
Piss Rev Mafia Member
7:26 AM
Central Ohio
need a choke lever/linkage and ignition switch parts for a custom restoration project
parts/cash etc available for trade
Dave
295 tramp
Hillbilly Saws
6:26 AM
Minnesota
I'm helping Dave out on his S-10 build .
It has a cylinder I have never found on a stihl that has a iron or steel chromed liner.
IPL shows it in a cylinder and piston kit 1108 020 1202 and says its a corben.
the only one I found was different with the inpulse area.
The one I have here can possible be cleaned up using MMs
method.
But we still need a complete clutch assembly with the drum and bearing.
Also the choke rod and contact spring for the kill switch.
And the front handle plastic support that mounts on the handle and fastens to the side of the starter.
1108 series clutch parts and handle support are the same.
Choke rod and contact spring only from a rear handle s10.
295 tramp
Hillbilly Saws
6:26 AM
Minnesota
Dave told me he had possible found the clutch setup and the handle support.
still looking for the contact spring and the choke rod
skip sail
11:26 PM
Victoria Australia
they show up out here in Oz more often than in the US,as far as i can tell.
I dont want to strip mine down,(too good) but as soon as a roughie shows up,will let you know
295 tramp
Hillbilly Saws
6:26 AM
Minnesota
The contact spring has been found.
Just looking for the choke rod and grommet
Thanks
460cixy
11:26 PM
Canberra
Anyone got a complete ipl for this model?
