mobilemech
Active OPE Member
- 11:54 PM
- Aug 19, 2018
- Redding CA
Stihl part # 1137 022 0564a is this an early or late cylinder for a ms192t?
No problem. It’s all good. In that case you’re in the right spot.Not a want to buy. Asking for info on what it fits. Please move to proper area. Haven’t posted here before, my apologies for incorrect area
That part number is cast into the cylinderI can`t tell you, because the number is wrong. Often there is not the right part no. on the part itself.
Reason for the question is; I’m looking for a early 192t cylinder, without the exhaust relief port, like in the 192tc cylinder
Because the compression of the early t models is significantly higher than the 192tcUm why?
A bit but the other starts easier and revs better imo. Make it a screamer.Because the compression of the early t models is significantly higher than the 192tc
