WDC1
OPE Member
- 7:31 AM
- Sep 16, 2023
- Northern California
After rebuild where I installed a new Stihl OEM carburetor and coil. I'm having a spark issue. I set the coil gap using a business card as I've done many times before. The problem I'm having is there is spark when using the old spark testing tool which looks like a flashing neon light indicating spark. When I insert a new plug as well as the old plug. I cannot get a spark through the spark plug. Advice or suggestions would be appreciated.
Why would I have a spark indication test tool but not through the spark plug? Is it a possibility of two small of coil gap?
Whereas I've never had a problem with the business card method when gapping the coil for precautions. I just purchased two Stihl OEM COIL GAP GAUGE SETTING TOOL.2mm - 4118 890 6401 as well as a .35mm 1127-890-6400. Since I read that the coil gap should be between .2 and .5.
