Stihl Haters, help me out!
Orangeinthebarn
10:43 AM
Tennessee
The new 550mkII is available still I think, you might have trouble finding a new MS261.
I bought a 261c in November manufactured date October 2020. Dealer placed order for it in Feb. so they are starting to show up. Another store just got in a nov 2020 manufactured 261. So they have started recently shipping
Ketchup
Epoxy member
8:43 AM
Colorado
261 is a top tier saw. It can also be had in a standard carb version, which solves the hot start issues and makes some parts cheaper. My consistent complaint with them is that the pull starter disintegrates over time. They port pretty well too.
346 is still better if ported properly. More speed, similar or better torque. Slightly heavier though, and not as good stock. The ported ones seem easier to burn up and the carbs are a bit more erratic.
Dolmar 5100 has nice torque, but is heavy and doesn’t seem to gain as much in porting.
550mk2 is better than mk1, but still has starting issues. Not sure what can be accomplished with good port work.
026/260 just don’t have the nuts the others have. The quad transfer 50cc saws walk all over the older design. Not bad in a budget scenario though.
There aren’t a lot of Stihls in my personal quiver, but 261 is one of them. I prefer 346, but you can’t go handing your ported 346 to a new groundy.
4:43 PM
I might need help building a bigger shed!
Don't keep them all in the same place!
You scatter them around inside Your house!
I can recommend a Makita EA5000/Dolmar PS-5105 (same saw).
But mine is stuffed with XtraSausages, I never ran a stock one.
59billy
Unknown OPE Member
9:43 AM
MS
Thanks for all the excellent suggestions!
I found an 026 that feels right.
But that doesn't take any of your suggestions off the table!
4:43 PM
82f100swb
9:43 AM
Dryden, ON, Canada
I have a couple 026's and a MS261. My 261 is a gen 1, carbed. I grab my ported 026 before the also ported 261 every time. I just like the feel of the 026 better, it's smaller and feels lighter in the hand.
The 026 is slightly stronger as well, but the 261 had cylinder damage that I ported out so timing #'s aren't exactly where I wanted them.
Turner Saw
10:43 AM
Ohio
I recently picked up a couple ms260's cheap with scored cylinders. I didn't have any prior experience with this model but after cutting the bases and porting them they are a great little saw. A friend of mine who does tree work has one of them now and loves it! He runs new Stihl M tronic saws regularly.
fearofpavement
10:43 AM
Georgia
I feel that the Stihl 026 is one of the best chainsaws ever made. And I've owned and used most models of most manufacturers. It's a model of saw that will always be in my line up. Any saw will cut wood if you keep the chain sharp. Some saws just feel better than others to me and my preferences are partially based on that. I've owned an 026 since shortly after they came out 30 years ago and still have 2 or 3 of them including that one.
ayoungtexan
I tell a lot of lies
9:43 AM
Dallas, Texas
Depends on what you want
Value - Echo 4910- basically a 490 with a 501P engine
Power - Makita EA5000 or Husqvarna 550MKII
Lightweight - Echo 501P
Build Quality - Makita 5000
Best Alternative (IMO) - Makita EA5000
But none of them compare to the 261
FergusonTO35
10:43 AM
Boonesborough, KY
Wow, that is a good deal indeed!
But none of them compare to the Dolmar 5105
Fixed it for you.:p
