Stihl fuel tank grommet sizes
Carhartt
5:09 PM
Central Pa
Does anyone have the fuel tank size grommets for Stihl saws that will allow you to eliminate the OEM style Stihl fuel line and use bulk line? I realize the hole OD is different on some saws. I believe Stihl part# 000 989 0516 will fit the larger hole of the 044/046, etc. I have tried a few grommets and they don't hold up well to the fuel.
TJ the Chainsaw Mechanic
Old Homelites rule!
2:09 PM
Most of the older trimmers use tank grommets with bulk line. Seems most they get is about 5 years without fuel starting to seep a little. Heck even some brand new lines and grommets I have used have seeped some fuel. Any particular reason you want to run bulk over a formed?
Carhartt
5:09 PM
Central Pa
Easier to stock bulk line for repairs. Plus some of the Stihl lines are short and a heck of a time to get the fuel filters on inside the tank unless you pinch the carb end hose so it doesn't fall in when u push it through to have length to get filter on.
Canadian farm boy
“Normal” people scare me.
5:09 PM
Ontario, Canada
028 comes to mind here
Carhartt
5:09 PM
Central Pa
EXACTLY. Last one that got me thinking this. I use 038 lines they are longer. You have to trim the supply end.
Poleman
3:09 PM
Rapid City,S.D.
Try using the old grommet from the old line, enlarge the fuel line hole then put in the saw tank, lube the line up and pull it through. New fuel line from bulk.
I use this method on older saw that have tough lines to get and someone wants their saw yesterday.
Chainsaw Jim
Con Artist LLC
2:09 PM
Springfield Oregon
Epoxy or JB weld a plate over the opening and drill a hole to fit the fuel line.
I've also used the old fuel line grommets. You cut the hose off each side and then use a high speed drill bit to drill it out large enough to fit the fuel line nice and snug.
Carhartt
5:09 PM
Central Pa
I have used the old fuel line and drilled it in the past. It is also another solution.
