Stihl compression tester
panteliss
11:26 PM
Europe
I am interesting for more informations about the tool in the photo , if is good no good accurate no accurate
thanks
CTYank
Killer of Invasives
5:26 PM
CT Panhandle
Looks like it has a rigid brass stem. That could put some stress on things, much more so than one with a (flexible) hose. Maybe they wanted to reduce the internal volume of the tester? Also, if it doesn't have a (super soft spring) schrader valve at the plug-bore end, that'd be a negative.
Over here in the USofA, I've had good results with Snap-On, Owatonna and others- with flex hoses and aforementioned valves at the plug-end.
Good Luck.
