AVB
- 11:54 PM
- May 4, 2016
- Elora, TN
Got any ideas on how to get the fan off. I have already sheared off the a 1/2 dr to 3/8 dr impact socket adapter and can't it loose with regular 1/2 dr 17mm socket either. It isn't for the lack torque either as the impact is rated for 950 ft-lb working torque. Rope trick of the cylinder hasn't worked either. Engine needing bearings. Thinking of trying to disassembly the engine so I can get a hold on the crankshaft directly.
Dang it shouldn't be on that tight.
