WANTED Stihl 461 cylinder needed
Frankavich84
1:00 PM
Des Moines
As the subject indicates. I need a cylinder for a 461. Clean please or just transfers is fine. I have a good piston but someone really messed up this spark plug hole and then tried to fix it to only make it worse. Otherwise it is a really clean saw. I’d hate to put it to parts when it is only missing a cylinder to be 100% oem.
Frankavich84
1:00 PM
Des Moines
That’s what the tried. I put one in late last night and it seemed to hold. Just not super confident on them.
12:00 PM
Can you post a pic up? And maybe @srcarr52 might be able to chime in on the fix. He has the smarts and stuff, and he is in your state.
srcarr52
1:00 PM
Iowa City
It doesn't matter how bad the threads are messed up, I have to enlarge the hole to around 1" at the top and 5/8" at the camber to be able to get the tig torch in to weld it shut.
12:00 PM
So does that mean finding a new or used one would be the best option then?
Frankavich84
1:00 PM
Des Moines
I ended up getting the fix a thread to work but time will tell. Should have just sent to you.
