WANTED Stihl 064 , 066
59billy
11:50 AM
MS
I'm thinking that @Bill G has an 064 runner and a project saw up for sale.
59billy
11:50 AM
MS
and around 3000 other misc saws, lol
last I talked with him he still had pallets of used saws he hadn't even gotten around to unpacking 🤣
And you've got pallets of NOS NLA parts fir them!
Fabulous
12:50 PM
Pa
Whole, running saw or boxed project? 🤪
Whatever is available - I’ve a saw at a builder in NY but my Bearing pockets in the cases are wallowed out. Could try metal epoxy as a last resort if nothing materializes 🤣
EFSM
11:50 AM
Extreme southern IL
I’ve already used a feeler gauge shim and extra-high strength thread locker in a pinch.
It’s not like you have to do something special to beat the strength of aluminum.
Fabulous
12:50 PM
Pa
Well … the guy building the saw for me prefers new oem … to reweld and line bore is cost prohibitive and the epoxy may/may not work satisfactorily long term
Fabulous
12:50 PM
Pa
I sent a tired 064 to a builder in NY but upon further investigation he said the bearing pockets were wallowed out and it wood be best to try and find a matching set of cases. Start from the beginning with new cases bearings / seals / gaskets
EFSM
11:50 AM
Extreme southern IL
my bad I badly misread your post
singinwoodwackr
10:50 AM
moon
Bearing pockets can be replaced. Contact Brad, Hdtoolmkr765 on AS.
He’s doing two 372xp halves for me.
singinwoodwackr
10:50 AM
moon
I have several case pairs. They just ain’t pretty :p
Fabulous
12:50 PM
Pa
From what Frankie told me everything has to be dead nuts true here - really NO margin for even the slightest error. From what he said you could bore the wallowed out pockets , install an oversize bearing OR install a bushing and then machine that bushing to size and press the bearing in OR use a metal repair epoxy … Seems like either way would work but a matched set of cases wood be sooooo much easier to work with and be around the same cost and much less effort.
