Stihl 045av bearing help
JTV10
9:02 PM
Wisconsin USA
Having issues finding the pro side bearing and seal on a 045av. Part number 9523 003 0440. The part is a bearing/seal combo. I think the 056 bearing with separate seal may work part numbers 9523 003 4460 and 9640 003 2690. Can anyone confirm these part number will work for the 045av?
jacob j.
Only the weird
7:02 PM
Coastal Oregon
The 045 PTO bearing has been NLA for 30 years. The 056 bearing set-up should work if your 045 crank has the 17mm diameter stub shaft on the clutch side. The 056 bearing is also NLA but it's a lot
easier to find as there's new old stock out there with many long-time Stihl dealers.
ktmtigger
10:02 PM
Do you have the old bearing and seal?
ktmtigger
10:02 PM
If so find an eastern industrial automation near you or call them and they'll ship it to you
JTV10
9:02 PM
Wisconsin USA
I found the bearing with the integrated seal. My dealer had 1 left in the back room. No box but it was in a bag. $75.00 took her home.
