FOUND IT Stihl 024 cylinder
jacob j.
Only the weird
2:58 PM
Coastal Oregon
Are you looking for just a regular 024 cylinder Tom, or the super?
trooney
Admitted Woodaholic
5:58 PM
The land of pleasant living
A regular J. Its got a Super cylinder on it now, owner scored the piston, and its on an 024 frame. Going to keep the cylinder and replace it with a regular 024 .
trooney
Admitted Woodaholic
5:58 PM
But if I remember correctly they are different strokes, right? Will I have to go with an 026 cylinder?
jacob j.
Only the weird
2:58 PM
Coastal Oregon
The regular 024 and Super have different cranks yes, so you can't just put a regular top end on a chassis that has the Super crank.
You'll either need to stick with the Super cylinder or go with an 026 cylinder.
trooney
Admitted Woodaholic
5:58 PM
But if I go with the 026 cylinder, will I have to switch out plastics, air filter and cover?
jacob j.
Only the weird
2:58 PM
Coastal Oregon
Not necessarily, like Dr. Al @drf256 pointed out, you can file/grind down the rear two cooling fins on top of the 026 cylinder so it'll fit under the 024 covers.
trooney
Admitted Woodaholic
5:58 PM
Yeah, but its a super that was under an 024 AV cover. An 024 cylinder wouldnt be good. I got the feeling whoever had it before rebuilt an 024 to an 024S. It has the front tensioner. I'm probably just going to rebuild it.
Lightning Performance
5:58 PM
East of Philly
Can you fit a different piston to your jug and saw?
