Stihl 012, need a little help.
czar800
1:26 PM
Ellwood City
I've got a 012 on my bench that's leaking fuel into crankcase. After looking around some I'm finding out they could have used to different gaskets? Should I just make a gasket? Thanks in advance.
czar800
1:26 PM
Ellwood City
I only have 518 laying around at the moment.
Lone Wolf
1:26 PM
Nj
Well sometimes you need the gasket to keep the crank shimmed right. No gasket it could jam . I would make one and check the crank to see if it spins freely after together.
Adirondackstihl
1:26 PM
Upstate NY
You sure the carb isn't the culprit?
Weak metering spring, worn needle, stiff metering diaphragm......etc, would cause that as well.
czar800
1:26 PM
Ellwood City
Oops quoted the wrong guy.
I was thinking you needed to gasket also.
czar800
1:26 PM
Ellwood City
Not my favorite series of saw to work on.... Btw carb kit is in the mail.
67L36Driver
12:26 PM
A client has an 012 that runs and cuts great. Head and shoulders better than an 011. Must be the displacement makes the difference.
Black Dog Chainsaw
Mak-Crazy
1:26 PM
Indianola, IA
PM me your email address
No problem
which carb it has makes 1000% difference. The early ones had a pretty narrow venturi as I recall. the 009/010/011's should all have 38mm P&C's and the 012's had 40mm (all from memory).
OP,
Yes use a gasket but use a thin layer of yamabond, 3bond, dirko, hondabond, etc on both sides of the gasket. They are a bigger PITA to seal than normal crankcases since you are needing to seal oil tank, gas tank, and bottom end.
Yes there are 2 different gaskets!!! just get the kit
http://www.ebay.com/itm/STIHL-CHAIN...KET-SET-/361475162645?&_trksid=p2056016.l4276
images
sefh3
1:26 PM
MI GO BLUE!!!!
My 011 is paperless. Just use a generous amount to assure you don't have a leak.
czar800
1:26 PM
Ellwood City
We have a winner!! I rebuilt the carb and it's running nice. Thanks for the IPL.
