Spark plug cross?
Joe Kidd
I reckon so
4:53 AM
NC
I've read tons of bad comments on Torch spark plugs. Best I can determine that a NGK BPR6HS replaces a E6RTC Torch??
Joe Kidd
I reckon so
4:53 AM
NC
Small Chonda portable gen.
Wonkydonkey
Plastic member
9:53 AM
Sussex, UK.
I’d guess and look up the Honda genplug is then see if I could see what some seller on eBay was saying your torch plug was a replacement for.
I searched for gx160 plug and this came up
Or you could justy put your torch number in here, link below and see all the plugs that would fit
And the torch plug for this is f6rtc
But I guess if you look at the pic you can see what plug does what, ie hotter /cooler or with a resistor etc.
Hop this helps 👍👌
