Silicone spray lubricant
davidwyby
Rural desert logging
11:45 AM
Extreme Southeast CA
F31E86AD-15DE-4DFC-BC9C-E7F21D640D66.jpeg 7C99E8D3-25EE-48D2-8BA3-DE7E62193D36.jpeg EF21BA86-8F3B-40EB-B1AB-B81B5DC50C81.jpeg Love this stuff. Dissolves and cleans out crud and leaves lube behind. Smells good and looks good on a saw too. Spray, soak a bit, blow off, assemble.
This is on my old 395 that I went thru a couple years ago and neglected to go thru the brake parts then. I got into it because it borrowed the flag to try on my 266 with full wrap. Which reminds me, I need to see about reproducing those full wrap brackets when my CNC guy gets back.
Ronaldo
1:45 PM
Eastern Iowa
First discovered it’s handiness for old sticky seatbelts.
I have a seatbelt that does not like to retract. The spring seems strong enough. How, exactly do you use it on them?
Sent from my SM-G930VL using Tapatalk
PA Dan
FYD
2:45 PM
White Oak PA
Here's what I got.
angelo c
Coal Member
2:45 PM
I spray it on my 201t when I'm going to be cutting pine. Helps to clean it up a lot easier.
Rubbing alcohol in a spray bottle with a little dish soap for suspension after pine works great too. Same on yer pants... Spray all over then rub with a brush and throw in the wash...messy peasy
davidwyby
11:45 AM
I think I’ve only used it on sticky seatbelts latches.
If you could get it to the mechanism I think it would help. Helps sticky ratchet straps.
