RedMax ebz 7500 coil problem
angelo c
Coal Member
10:54 AM
Guys,
Trying to locate/order a new oppama coil for a Redmax ebz 7500 back pack blower.
Oppama # on the actual coil reads A 10026 1101
I can't find a serial # for the blower but it has a MFD of 2011
engine group BHQZS 0665GD
help as to locating a SN or other ID info to order the coil would be great
thx.
A
smokey7
10:54 AM
Detroit
We have several of those at work.... I can look Monday and see if I can get some more info for you. Great blowers tho. Have you made sure the stop switch isn't stuck down in the throttle handle? Very common on ours at work.
panteliss
4:54 PM
Europe
Guys,
thx.
A
583916701
angelo c
Coal Member
10:54 AM
Thank you sir
yes, I swapped the coil out for one I know had a bad shut off switch and it fired right up.
Good units. I had a bunch that the fan cage bearings went bad on but it's an easy fix.
Handles seem to be a weak point, but they swap out easy too
