Philbert
Chainsaw Enthusiast
- 4:27 AM
- Jan 30, 2016
- East Dakota
I ordered a Redback 120V, battery-powered pole saw at a seasonal clearance price. I already have the chainsaw, and this one with a battery and charger was actually cheaper than buying just a spare battery by itself, so it was a 'good deal' (note: price has varied on line).
https://redbackpowerusa.com
The polesaw telescopes 17 inches, from 78 inches to a maximum of 95 inches (tip to tip). With the battery and guide bar removed, it collapses down to 71 inches for transport or storage. Shaft length is adjusted with a twist lock (at first I was confused by the sliding, shoulder strap mount which adjusts with a cam lock).
The '8 inch' (nominal) bar measures 7-1/4 inch, and runs 3/8 low-profile, narrow-kerf, chain. It was supplied with TriLink, semi-chisel, low-kickback, skip-tooth chain. The bar is angled downward at a fixed, (approximately) 15° angle. It has a tool-less chain tensioner, which was quite stiff initially, but may loosen up with use.
Bar oil is added via a real 'flippy cap': a hinged flap, almost like a detergent bottle. Innovative.
Philbert
Philbert
