SELLING Rebuilt stock 359
Trader history (3)
Disciple of Monkey's
11:24 PM
Up for sale a stock 359 pho that I rebuilt myself from the crank up. Asking price is $450.00 plus actual shipping, with reasonable offers considered also.
The saw has a new old stock true 359 OEM piston and cylinder kit installed as well as real McCoy SKF Explorer 6202 bearings. Otherwise, a mashup of OEM and AM parts including a brand-new Stens C3-EL 42 carburetor and Hyway jungle style muffler being the biggest two.
A tension spring on one of the seals had failed leading to the original blow up of the saw. It had not quite one sprocket worth of wear on it to give you an idea of the time put on it and still has the sticker on the bottom of the tank for another indicator.
Saw starts easy and runs and oils as it should. Will make someone an excellent firewood saw.
11:24 PM
Some other notables about the saw, the intake partition and clamp were replaced with the new version with metal clamp from Husqvarna. Which should help eliminate a possible future failure.
The saw was tuned to 13,000 RPM for break-in, 13,500 is the maximum.
The metal side plate was replaced to help prevent oil leaks.
Saw is as clean where you can't see as where you can.
11:24 PM
Also open to partial trades for parts, parts saws and builder saws, never know what will interest me, so let me know what you have and see if we can make a deal. :)
