SOLD Rebuilt stock 359 - Reduced 3
Trader history (5)
Disciple of Monkey's
6:02 PM
Up for sale a stock 359 pho that I rebuilt myself from the crank up. Asking price was $450.00, NOW $400.00 plus actual shipping.
The saw has a new old stock true 359 OEM piston and cylinder kit installed as well as real McCoy SKF Explorer 6202 bearings. Otherwise, a mashup of OEM and AM parts including a brand-new Stens C3-EL 42 carburetor and Hyway jungle style muffler being the biggest two.
A tension spring on one of the seals had failed leading to the original blow up of the saw. It had not quite one sprocket worth of wear on it to give you an idea of the time put on it and still has the sticker on the bottom of the tank for another indicator.
Saw starts easy and runs and oils as it should. Will make someone an excellent firewood saw.
6:02 PM
Some other notables about the saw, the intake partition and clamp were replaced with the new version with metal clamp from Husqvarna. Which should help eliminate a possible future failure.
The saw was tuned to 13,000 RPM for break-in, 13,500 is the maximum.
The metal side plate was replaced to help prevent oil leaks.
Saw is as clean where you can't see as where you can.
6:02 PM
Hard to believe this hasn't moved. Guy could buy it. Run it hard for a firewood season and sell it next year for $400 plus shippin
Be fine by me, just some nibbles so far, nothing I could set the hook on just yet.
I'd have kept it for myself had I not gotten another with heated handles on it to take its place.
