- 4:03 PM
- Dec 29, 2015
- Ontario, Canada
I completely went through this saw a couple months ago. Has approximately 15-20 tanks of fuel on it since the rebuild. It has an oem dual port muffler that I opened up a little. I also did an ignition advance.
1309 coil
D chamber jug.
The jug had some transfer I cleaned off. It has a couple very light marks in the plating. The marks can’t be felt and just appear as shiny lines. Nothing I’d ever worry about.
The decomp is plugged but I can put one in if wanted
List of new parts
-crank bearings
-gaskets and seals
-piston kit and wrist pin bearing
-impulse line
-fuel line and filter
-rebuilt HD-15 carb
-grommet for carb screws
-proper 046 dual felling spikes
-7T 3/8 rim
-ngk spark plug
Possibly more new parts that I can’t remember. I wanna say I put a new intake manifold on it but I’m not 100% positive if I did or not.
Everything is oem except for the SKF 6202 C3 flywheel side bearing.
I don’t have a pic but the comp blows 155-160 when I last checked it.
The saw runs strong and everything functions as it should.
Asking $700 USD plus shipping from Canada
The saw could be ported for a little more $ if the buyer wanted.
1309 coil
D chamber jug.
List of new parts
-crank bearings
-gaskets and seals
-impulse line
-rebuilt HD-15 carb
-7T 3/8 rim
-ngk spark plug
