Project bent shaft!
CoreyB
1:55 PM
South east iowa
I found a deal on a Husqvarna 128l that was brand new but the shaft got bent in shipping. Then the dealer parted it out. So it was missing the starter assembly, trimmer head and all hard wear. As well as the debris shield. After a quick inspection the cable I realized the cable was not dragging or rubbing the inside of the shaft So basicly I got the trimmer for a deal that would make most say " you suck! " so I have a new trimmer thatisin ok. So I am making this a project to see howcheaply I can make a this a little work horse.
CoreyB
1:55 PM
South east iowa
So after trimming a while I was not over impressed. I mean it wasn't bad just ..... Well just ok. I also noticed how hot the little bugger got.bi could tell it had to have a cat in the muffler. So first performance upgrade ( andprobably the only) was to figure out how to either remove or bypass the cat. The MUFFLER is not easily split in half do to it having an over lapping pressed together seam. So after a quick inspection a found just bypassing the cat would be the fastest.
Nitehawk55
2:55 PM
Ontario
Projects like that are always fun and something to learn a bit about .
