r7000
Anyone know where to buy and what they are called?
Came across an unusual pressure washer wand tip. It was a 0° pattern, but said 40 on it also, and unlike the red 0° pencil tip that fogs after around 20 feet from the tip this one was like a garden hose stream where you could reach 40' high or more from the ground to shoot water... and get bleach chemical onto an upper part of a 2 story house without having to use multiple wand extensions going 30'. With one 6' or 10' wand you could adequately reach 50' high with signficant enough pressure from a ~3000psi pressure washer to clean house siding way up. The tip had no colored plastic on it, looked much like a male air hose fitting.
