predators and other varmints
alleyyooper
12:36 PM
Michigan.
We will clip extra goose or turkey feathers to the tail to make them look bigger.
Two of our group members have ones like this. sort of worth Less once the ground is frozen. At least mine slides into a 12"x12"x2" block of rough sawen oak I carry in my back pack.
:D Al
justoldsaws
From the land downunder
3:36 AM
Got these 4 last night, put another down with the .17rem but was unable to find him, im guessing it crawled away badly wounded. Farmer will find it.
Was calling with a cheap ebay caller called the Fox Blaster, worked really well, even called in an owl.20190401_205149.jpg 20190401_011745.jpg
alleyyooper
12:36 PM
Michigan.
Which Ico Tec caller do you have? I have a GC350 it works great and love the abilty to use different calls with a SD card to hold them.
I found out you have to use the smaller GB cards though.
Gather sounds from Farms on a recorder and install them on the card. Piglet in distress is a favorite, along with a lamb in distress. Amazing no wild pigs in the area we hunt nor even a pig farm and the coyotes come in smoking hot some times.
:D Al
justoldsaws
3:36 AM
I have the base model, so it just has the fixed calls, works well on the foxes, mostly use woodpecker, cottontail and jackrabbit distress calls.
alleyyooper
12:36 PM
Michigan.
We run two calls at once with two different sounds. Last outting had a female coyote in heat then a piglet in distress sound.
Guess the ones that came to check it out had two things on their minds food and SEX in no special order :risas3:.
:D Al
amberg
12:36 PM
Va.
8 from last night, another hit in the chest but be made into rushes i couldnt find him.
Lots of lambs are being born at the moment, foxes are hanging around for a easy feed.
This little Tikka in .17rem is a cracker of a rifle.
Again, I am impressed! Keep up the good work!!
